Eds Vans RV-6A/7A Web Site
Date: 12-1-2009
Number of Hours: 0.00
Brief Description: Make drill bushings for drilling engine mount.
I still haven’t finished riveting up the fuselage. Stephanie and I team up on that now and then but still have the entire forward section to do. So, let’s drill the engine mount while the firewall is still removable.
I want to drill the engine mount now so that I can make a rotisserie. Also I’ll like to drill it now because the engine mount can still be removed. I’ll drill it straight down on the bench.
The engine mount attach holes are 3/8” but I wanted to step it up to either 3/16” or 1/4” for the rotisserie and final drill it to 3/8” later on. So, I needed some bushings. A quick trip to Nappa I found just what I needed to make the drill bushings. I bought 4, 12” long brake line tubes. Each fit inside the other.
Tube 1, 3/8” OD, 5/16” ID Tube 2, 5/16” OD, 1/4” ID Tube 3, 1/4” OD, 3/16” ID Tube 4, 3/16” OD, 1/8” ID
I can start with a 1/8” bit, then a 3/16” and then a 1/4". Later on I’ll finish with a 3/8” bit or reamer.
I Made a total of 6 bushing sets that step down to 3/16” and are just a bit shorter the engine mount mounting tube. I made 1 bushing set that steps down to 1/8” and it’s a bit longer then the mount tube. I’ll use this longer bushing set for drilling and the shorter sets for mounting.
Am I over thinking this? I may be.
4 brake tubes from Nappa.
1 Drilling set and 6 mounting sets.
Ready to drill the first 1/8" hole.
