Brief Description: Drill Seat Back F-637B veritical angles.
Used the drill press to drill all the previously marked holes. Clamped a fence to the drill press table so that I get consistent hole locations from the vertex of the angle. Worked great.
After drilling the first angle I used it to back drill second. This way I can avoid measuring and marking hole lcations again. Then I used the second angle to match drill the third. Then again used the third angle to match drill the fourth.
