Brief Description: Fuselage - Rivet aft end of outside seat rib, F-71
I may have been able to rivet these 2 universal rivets solo but the single offset set has to be used. It’s just a bit harder to use solo. So, Stephanie came out and held the Tungsten bucking bar. She’s great, patience and cares as much as I do.
I then contemplated riveting the aft end of the armrests, but I see that they can be rivted on easy after the skin is on.
I then contemplated riveting on the 763 baggage corner rib by the conical bend. Again, Stephanie can help buck it later after the skins are on.
I put the forward main spar back on as seen on the next log entry. Then I put the side skin on.
