Brief Description: Center Section - Rivet center floor rib access pla
Rivet up these center floor rib access plates. Easy. The only deviation from the plans is that I did 4 instead of 2. Doing 4 allows me to install or remove the control stick mechanism as a whole. Lots of builders are doing this. Seems like a good idea.
