Brief Description: Fit 711, 712 Bulkhead to Tail Cone.
The tail cone is under bent and no way are clecoes going to bring it all together. Here's what I did to curl the tail cone a bit more.
Also, it's a bit of a challanging to get all those mini flanges at the correct angle to fit flush in the tail cone. You wouldn't think so but it took several iterations.
You can see the amount I had to bend the sucker between image 2 and 3 to change the curl.
