Oh man, I'm ready to be done with the 704 buckhead. Last step for now is edge finnishing the 704H's. This part connects the 2 main spar center sections.
Still left to do from the instructions is reaming out a hole in one of the spars for a spacer bolt to 1/4 inch. I've read that it's better to wait untill the two half's of the spar are bolted together so that you getter better alaignment betwen the two spars..
Also the hard wood spacer will have to wait. Lots of disscussions in the fourms about the need for this spacer and the material to use to make it. I'll deviate from the plans and use some aluminum tubing with 1/4" inside diameter that the smaller wing bolts can fit through. Easy and precise.
