Brief Description: Trimmed and drilled the wing walk doubler plate.
First you trim 2 wing walk doubler plates from larger stock sheets. You then clamp the trimmed sheet under the inboard top wing skin and match drill all the holes. I drilled right into my bench and put clecoes in the holes to hold it in alignment. I held the shop vac close to the hole to avoid cleaning up all the aluminum chips later.
