Eds Vans RV-6A/7A Web Site
Date:  1-17-2008
Number of Hours:  0.00
Brief Description:  Wing tie down spacers.
Cutting a bar of aluminum into 4 spacers that fit between the wing tie down bracket and wing main spar.
Each spacer needs a 1" diameter hole.
This was not easy.
I used a hole cutter modified to cut a 1" outer diameter hole.
Clamped it all down and went to town.
The hole cutter whould only go throug half way.
I turned the spacer over and finished it from the other side.
Worked out OK.
Hole cutter in drill press.
Rough cut.
Rough cut.
Finished cut
Finished cut
