Brief Description: Clamp doen the elevator trim tab.
Clamp down that elevator tab. Have to be careful about the inside block size and shape. Interesting angles.
I ran a piece of wood length wise so that the inside block does not move when I pound on it.
Used a small block of wood and hammer to get it close and then used my flush rivet set to get the tabs really flat. I set the pressure regulator at the tank to 10 pounds. Not the tool regulator. The tool pressure regulator is really a restrictor, not a regulator. Setting the tool restrictor low has the effect of a few hard smacks before it settles down.
Setting the actual tank regulator at the tank kept the pressure at 10 pounds, even for the first few smacks.
