Brief Description: Finally looks like an airplane part.
The HS skin is finally clecoed on the skeleton. Still lots of work to be done on it though. Not all the rivet holes are drilled. It will need to be totally taken apart, dimpled, deburred, primed and then all riveted back together. Then do it all over again on the other side.
Lots of work up to this point. The ribs needed to be smoothed out, fluted and flanges needed adjustments.
