Brief Description: Fab F-703B, Canopy Deck Angle, Part 2
To get the 15 degree angle cuts marked, I cut 7.5 degrees on a scrap piece of minimum plate. Then used the plate to mark cut 2 lines intersecting the 1/8” hole. Then used the band saw to cut the notch. I used the band saw fence, set to 7.5 degrees, and extended the fence using a piece of scrap wood.
