Brief Description: Make fuselage rotisserie height adjustable.
Finally bit the bullet and make my rotisserie height adjustable. I also make an identical rotisserie stand for the tail end. Using a car jack I can raise or lower the height. Spins nice but is a bit bottom heavy. That will improve once I get some of the fuselage top parts mounted. Had to use care to assure the rotisserie ends mounted at right angles to the fuselage.
