Brief Description: Drill elevator horns at push tube end.
The plans have you first drill a #30 hole in one horn, then use a drill block to drill the other. The plans call out where to drill the first hole. But I had to move my hole 1/8” inward because the opposite horn is 1/8” shorter. If I had not adjusted this hole location I would have an edge distance problem on the opposite horn.
See post 4/4/2011 for pictures and description of this potential problem.
Of course, you know me, I used a 1/8” scrap to match drill the exact location of the hole. I really don’t know how to free hand a hole with out getting it off by at least ½ diameter. Just cant do it. I’ve tried.
