Brief Description: Roll Bar - Fill hole in 631C/D angle bracket. Part
Here is my damaged 631C/D roll bar angle bracket. As you can see the top hole is elongated. I really messed up and I don’t want to talk about it. I just want to fix it. So I’ll use Alum Fast H-455 Aluminum filled epoxy. I did a test with this stuff and it its amazing.
I stuck a ¼” Teflon rod in the bottom hole and filled the top enlarged hole with epoxy.
