Brief Description: Roll Bar - 705J/K/L buckhead interference. Crap.
Now this modification is bogus and should have been avoided but if you follow the plans you will end up making this modification. You’ll find you have interference between the 631C/D angles and the F-705J/K/L bulkhead parts. Interesting in that all the web logs I have seen I have never seen anyone avoid having to make this stupid fix. I’ll go back to the log entry where I made the bulkhead and warn other builders to shorten up the 705J/K/L by ¼” to avoid having to do this.
I simply removed the 3 outermost rivets, lifted the assembly and slid protective tape underneath. Using a small sanding drum in my rotary tool I just ground a bit away just like others. A little emery cloth and your done.
