Eds Vans RV-6A/7A Web Site
RV-7A
Drill shoulder harness cable wear blocks.
After marking the location of these shoulder harness cable wear blocks I drilled the holes. How did I drill the holes. Yep, you guessed it. I match drilled through a clamped piece of scrap. Holes are perfectly located. I’m so happy.
Marked cable wear blocks.
Match drill wear blocks.
Perfectly located holes.
Aerolite 103 Home
RV-6A Home
RV-7A Home
Finishing Kit
134
Flap Actuator
Hole Fixing
Personel
Roll Bar
57
Seat Back
Shop
Wing Cradle
Wing Hardware
Wing Jig
