My RV-10
Date:  9-11-2012
Number of Hours:  1.50
Brief Description:  VP-X Pro Starter Annuciator
I thought I would throw some photos in here this evening...
I have been running wires and such, not all that photographic.
Anyway, Installed the starter annunciator circuit this evening.
Soldered the 1K ohm 1 Watt resistor inline with the J2-11 circuit on the VP-X Pro.
Ran the wire through the firewall to starter side of the solenoid and powered up the VP-X.
Engaged the starter, and as you can see in Photo #2 and #3 the starter annunciator indicated the starter was active.
1K ohm 1 Watt Resistor
Starter Off
Starter Off
Starter On
Starter On
