Fabricated the ground cable from the battery to the firewall. Fabricated the positive cable from the battery to the master solenoid. Installed the master switch, and starter switch to test the circuit. Hooked up the VP-X Pro, powered up the system, along with my laptop. Checked system voltage, and tested the starter circuit, and simulated RPM to make the starter would not engage, VP-X will not engage the starter after 600 rpm is indicated.
