My RV-10
Date:  4-10-2012
Manual Reference:  VP-X Pro
Brief Description:  Vertical Power VP-X Pro Test Bench
After making up my mind on switches, and the layout...
I found a laser engraving shop about 2 miles for the house, so when the time comes I will let them work their magic.
Continued to focus on my test bench for the VP-X Pro and associated circuits.
Bought a 13.88 Volt 19 Amp power suppy from Radio Shack and mounted it to my bench.
Mounted the VP-X Pro and installed a grounding strip.
Connected the PS with an inline 15amp fuse 12ga wire to the VP-X and pinned out one of the ground wires for the VP-X. (The VP-X has 2 redundant grounds)
Powered everything up, and verified everything was in order by hooking up my laptop...
I should take deliver of my Master and Starter solenoids tomorrow.
I plan on testing the flap system in a few days, since I have all required components.
Test Bench VP-X Pro
Test Bench VP-X Pro
VP-X Pro Powered Up
VP-X Pro Powered Up
