My RV-10
Date:  1-18-2014
Number of Hours:  3.50
Brief Description:  First Engine Start Successful
Went to the airport early this morning...
I finished up some odds and ends in the engine area.
Wheeled the aircraft out... tied it down and prepared for first engine start.
My helper and I set up the 3 video cameras, fire extinguisher etc.
You can see it here... this is a un-cut version of camera #1... Probably take me a couple of days to combine and edit the other videos... I am fairly new at editing.
http://youtu.be/S4wSfnT87QQ
Descrepancies:
Tach was reading 2 times normal... 1200rpm was indicated as 2400rpm... Skyview Setting.
#2 cylinder EGT was reading 100 degrees colder than the others... need to check prob.
Slight oil leak from oil cooler return line... Need to torque AN fitting.
Started 2 blades through, ran smooth, cool, and strong...
CHT vs EGT
CHT vs EGT
Oil Pressure vs Oil Temp
