Connected the main fuel line to the carburetor. Purged the fuel system, and pressurized to the carb, and tested accelerator pump. Installed the airbox, and connected the linkage to the carb heat control. Checked timing to emags, and conducted a "pull" through test, checked successfully. Installed top plugs / torqued. Installed cooling shroud. Engaged starter... Oil Pressure check OK Engine Driven Fuel Pump check OK
