My RV-10
Date:  11-23-2013
Brief Description:  Carb Intake Airbox - Part 4
Drill mounting plate as required.
Installed on engine, installed lower and upper cowling.
Check alignment. Everything look really good.
Photo #2 shows the aluminum spacer, that slightly angles the airbox up.
It also allows the mounting plate to clear the aft carb drain plug. No cutout relief is required.
I have to adjust the carb heat control arm, it is making contact with the lower cowling.
Airbox Mount
Airbox Mount
Spacer Visible Below Carb
