My RV-10
Date:  12-31-2011
Manual Reference:  Lyc. Maint. Manual
Brief Description:  Engine Assembly
Began by checking the ring gaps...
Lubricated and installed Pistons for cylinders #2 and #3.
Lubricated, staggered,compressed the rings and installed the cylinders.
I chose to install cylinders #2 and #3 first because they share the case through bolts.
This way I can maintain the case center torque force while I wait for the other two cylinders.
Lubricated and installed the tachometer shaft.
New Pistions / Rings
New Lycoming Cylinders
Tach Shaft
Tach Shaft
