Big day today in preperation of first engine starts.
Pressure Bled the brakes... They are tight and touchy now. Took awhile, I have brakes on both left and right sides. Sealed the oil system firewall forward, Oil filter, oil lines to cooler, safety wired as required. Checked cylinder oil return lines, setup oil pressure line for purging. (Tomorrow) Adjusted Pmags and torqued... Adjusted alternator belt tension, torqued and safety wired. Torqued backup alternator pad nuts. Adjusted the propeller pitch to 20 degrees and torqued all bolts. Installed spinner assembly, torqued and safety wired as required.
