Stopped by the parts department yesterday and picked up the -6A bolts. I completed the assembly of the Vertical / Horizontal stabilizers, torqued to specs. Installed the Rudder and Elevators and ran the elevator wiring. Installed the elevator control horns to the push/pull control tube. Installed the rudder cables.
Check control movement from the cockpit... smooth and correct.
