Brief Description: Empenage Torque / Main Wing Bolts Torque
I worked on getting the empenage bolts torque to specs... For some reason I couldn't find the AN3-6A Bolts I needed for the vertical stabilizer. I will stop by the parts department and pick some up tomorrow.
I began the task of torquing the main wing bolts... I knew it was going to be a pain in the backside. I managed to get the ALL 8 of the main bolts torqued... The RV-7A model has the bolts pass through the main gear weldment, and it is pain to get the nuts in place... But I managed... My flexibility gave out... The 4 AN4-13A bolts are installed and torqued. The 8 AN4 pass through botls are installed but I still need to get them torqued...
