I believe I have the left wing tip pretty much complete. I riveted the trailing edge rib, and it seemed to remove that 1/4" difference I noted yesterday. Everything lines up fairly well... i am so use to everything matching perfectly, thanks the Van's. A 1/16" difference looks like a huge issue...
Anyway... I should have my roll servo tomorrow, and I will continue the final assembly of the right wing.
I began studying the plans for fuselage last night before bed. I hope to start on it in June. June will mark the 2 year anniversary since I started the RV-7A.
I am really learning a lot, and enjoy the construction process more than I thought I would. I can see why some folks build more than one...
