Finished the repair work on the fiberglass mounting section. Fitted the wing tip rib and drilled. Fitted the tip and checked alignment... I have the aileron rigging jig in place and the aileron lined up. The alignment with the wing tip is about a 1/4 in off... I will have to check the rigging during final assembly.
