Cut foam inserts for the Vertical and Horizontal stab tips. Epoxied them in place, shaped as required. Torqued the push rod bolts for the Elevator.
Layed out the stencils for the "N" number. Upper aft fuselage. I decided to just go with the 3 Inch numbers at this time. When it is ready to paint I will go with the full 12 inch numbers.
