Brief Description: Mountedd the Fiber glass elevator tips
I repaired the right fiberglass elevator tip... and installed. I pulled the airplane out of the hanger for a final engine run to check oil cooler connections. The run-up went fine, oil fittings around the oil cooler show no sign of oil leak. Conducted a full static run... 2290 - 2300 rpm. Mag checks, carb heat check all normal. That should do it until first test fight.
