My RV-10
Date:  11-16-2009
Number of Hours:  1.50
Brief Description:  Started Riveting Rear Spar Doublers
Studied the plans and marked the rivet holes that are to be completed with rib assembly.
We squeezed all the -4 rivets required at this time.
There are only a few rivets required at this point in the assembly.
As you can see I have not final drilled the #40 skin holes yet.
I plan on drilling and dimpling these parts as one. I did this technique on some of the empennage and it seemed to work perfectly.
Careful Rivet lay out
Rivet in Assembly
Rivet in Assembly
