My RV-10
Date:  2-12-2014
Brief Description:  Mountedd the Fiber glass elevator tips
I repaired the right fiberglass elevator tip... and installed.
I pulled the airplane out of the hanger for a final engine run to check oil cooler connections.
The run-up went fine, oil fittings around the oil cooler show no sign of oil leak.
Conducted a full static run... 2290 - 2300 rpm.
Mag checks, carb heat check all normal. That should do it until first test fight.
