Completed the final fitting of the under wing surfaces to the lower fuselage. I messed up the right fiberglass elevator tip, and will have to repair a couple of the mounting holes. Calibrated the flaps with the VP-X pro. Using a digital level I matched the right and left flap travel. I set the flaps to momentary travel via the flap switch as recommended for intial flight tests.
