Checked all fuel connections from the Left and Right tank to the carburator... Called the FBO and had the guys add 10 gals of 100LL to each tank. Checked for any immediate leaks from the fuel dranes and fuel tank connections. This is the first time the tanks have held fuel... so far so good.
Switched on the Skyview, and accessed the calibration screen for the fuel tanks... I check the sensor voltage: Empty L/R = .093v with 10 gal in tanks = 1.0558v both L/R Tanks. I accepted the calibration as is... to see if indications were shown on the gauges. The EMS gauge indications were showing 1/2 full... of course I will have to re-calibrate much more accurately later.
