Completed the final installation of the Roll trim motor and mechanical linkage. Researched a bit, and adjusted the tension on the springs. Used the mounting plate I fabricated, and it worked just fine, the motor has been installed. Hooked up the trim switch and tested... everything is working as designed. One thing you have to get use to... is the spring tension on the stick... It gives a centering feedback when you manipulate the stick. I tend to like it.
