Brief Description: Backing Plate for Aileron Trim Motor
I guess it would have been a lot easier to install the roll trim motor before installing the seat floors. Anyway, I fabricated a backing plate with nutplates that will go on the opposite side in the seat rib. that way I can just position the backing plate and screw the motor ro the rib. no trying to fumble around with loose nuts and washers.
I need to get a smaller 90 degree drill adapter to get all the mounting holes drilled.
