My RV-10
Date: 2-3-2013
Number of Hours: 2.50
Manual Reference: Sec 9
Brief Description: Boost Pump / Land Lgts Wiring / Canopy
Completed the electrical run for the Boost pump. Tested. Ran the landing light wires up to the planned terminal stip between the seats. One thing about electronic circuit breakers, even when the circuit is inactive (off) you will see residual voltage (11v) in the circuit with a multi-meter, But there is no amperage behind it. Being old school it took me a few times to get that through my thick head.
I really like to combination of the Dynon Skyview and VP-X Pro interface. It tells you just about everything you want to know about your electrical system. What circuits are active the amps each are pulling. Total system voltage / amps. Alerts for shorts, ability to reset, and if you have issues with a mechanical switch, the interface has "On/Off" electronic switches for each circuit. You could actually eliminate all your mechanical switches in the cockpit, would that look clean, I would not recommend it... But it's possible.
To change the pace, I began laying out the canopy, determined and marked the center lines. positioned the canopy frame where it followed the contour the best and mark the hole for the latch. Using a uni-bit I drilled the 5/8" hole through the canopy, and then dressed to hole smooth, inside and out.
Dynon / VP-X Pro Interface
Canopy Latch Hole
