My RV-10
Date:  1-22-2013
Manual Reference:  Sec 9 DWG 41
Brief Description:  Canopy Fitting
Fitting / Adjusting the canopy frame.
The forward frame legs that attach to the rollers were about 3/8" difference in length.
measured and trimmed to level the frame to the fuselage, which brought the top forward and rollbar measurement to the specified 3/8"
Measured and drilled the C-677 rear pin mount on the left side, along with the C-665 mount block.
Measured the angles to drill the 1/4" hole in the C-665 block for the canopy rear pin.
Drilled mounting hole in the C-665... Stepped it up via a pilot hole and then up the 1/4" and then used a countsink to open the lead in for the canopy pin.
Everything is looking good at this point.
Forward Canopy / Rollbar
Rear Left Mounting Block
Rear Pin Mount Assembly
