My RV-10
Date:  12-30-2012
Number of Hours:  3.50
Manual Reference:  Dynon
Brief Description:  Wiring / EFIS Backup Battery
This entry is for 12/27, 12/28, 12/29, and 12/30
Continued with the Instrument panel... It needs about 3 days to dry before the clear coat.
Even then the clear coat actually lifted the paint in a couple of areas, I will have to go with it.
I received the EFIS backup battery and mounted it just behind and to the left of the PFD.
Fabricated the mounting angles for the EMS and installed platenuts, installed temporarily.
Inspected and terminated a number of ground wires to the main grounding block.
Began the final wiring of the PFD harness into the aircraft. The wiring is about 80% complete.
Main systems are working... EFIS, EMS, Sensors, Flaps, Pitch Trim, Map Lights, Aux Power, etc.
Instrument Panel
Instrument Panel
EFIS Backup Battery
EFIS Backup Battery
