Trying to keep things simple... Not always easy with all the available options. Today I fitted the Skyview SV-D1000 in each of the cutouts. Drilled / Deburred / Countersuck. Cleaned and prepped the surface and applied 2 light coats of etched primer. Installed the nutplates for the skyview panels. Applied 3 light coats of the enamal (Almond) top coat, it is an off-white, almost egg nog color. I decided on this color because it is neutral, and has good contrast with the black lettering.
Photo #2/3 are examples of how the labeling will look...
