Pulled the wires for the pitch trim and tail light / strobes... Installed a terminal strip near the VP-X for the shielded wire runs. Connected test light to VP-X and checked position and strobe light switches etc. Pulled the wires for the carb temp sensor, terminated and wired to the main harness. Pinned out and installed Dsub connector for the VP-X and labeled the wires accordingly. Began to finalize the runs to the VP-X J10 and J12 and secure with tie wraps.
