Began to get everything together and organized for the crankshaft assembly.
References: Lycoming Direct Drive Overhaul Manual - 60294-7-9 June 2002 7-10B Sevice Bulletin No. 475C
Began by getting the Crankshaft drive gear ready for assembly and during the review of the parts required and the Mandatory Service Bulletin 475C I noticed the mounting bolt was out of date, and has been superseded, I had in my kit STD-2213, and the replacement bolt is STD-2246... could not get the gear installed.
So, I did the next best thing... I assembled and installed the connecting rods, checked tolerances... I applied an intial light torque, but need to take my torque wrench to the shop and check the calibration...
