I glued on the upper cowl hinges to start off today. We are having nice warm weather for the next couple days so it is nice that I have glass work to do. I am doing the upper cowl hinges like the lower cowl. I drilled holes in hinge to let epoxy weep out. The cowl is installed with clecoes holding the hinge while it cures. After a couple days to fully cure I will then rivet on the hinges. I should have a cleco less cowl after these hinges are done except for the Camlocs I have to install on the bottom. The cowl is fare from done but getting there.
