I had a problem with the small Molex connector on the right console, taking the thing in and out I have had two wires pull from the pins, they are tiny .062 pins, but I must have had a bad crimp. The Molex is a tight fit and takes a lot of pull to remove so I decided to come up with something new. I removed the console and found that with a little modification a DB9 would fit into the opening where the Molex was connected. I re-pinned everything with D-Sub pins and gave it a test fit and it now works great.
