Last day of the month and I made good progress today. The wires coming out of the intercom panel were interfering with the back of the panel, to fix this I needed to move a service loop but his required a new way to support the bundle. I made a support out of some angle stock, the bundle gets tied onto two tangs that protrude off the support. I retied things and then gave it a test fit.
After deciding things were going to work I proceeded to pull the some of the ground wires to the firewall ground block, these are fat wires that will not go into the instrument panel ground block. I then pulled the power wires for the main panel items. Then most of the rest of the say was spent organizing these wires and tying the vertical wire runs that go behind the CB panel. I also manage to hook up the last CB in row 2 and finalize that row, I only have 5 more circuits to complete then the CB panel will be done. Then I will have to tackle all of the grounds.
Bundle zipties to the tangs, heat shink to help protect the wire
