I organized the wires to the right side switches and began to lace tie them up. The only wires I still need to worry about are the ones that pass through the panel to the map light, side eyeball lights and the instrument panel LED stip. I had a hole under the longeron in the panel for the map and side eyeball lights but I needed to decide how to get the instrument LED light wires to the back of the panel. After some thought I decided on a small hole with a grommet right where the strip of LEDs ends.
I bought some hardware to secure the 25 pin connector I am using for my DSAB Hub. After securing that in place I began to lace tie the right side switch wires. I then tested the switch functions and continuity to the wires forward of the firewall and all worked perfect!
DSAB Hub on top, instrument ground bus on the bottom. These will get a connector shell.
