When I started to work on the rights side switches I realized that in order to organize the wires I needed them all there. I had not pulled the wires that eventually go forward of the firewall, these wires are for the ignition and the alternator fields. I cut each wire to length and then pulled the bundle to the firewall pass through. I am going to use one of the pre-punched holes on the right side of the firewall. I am also running the sensor wires for the Dynon this way. I have another pass through that I am running the high current wires through. After getting the wires pulled I finished hooking up the wires to the switches.
