I continued with the panel harness today. In hooking up the HS34 I noticed the bracket does not hold the box very solidly, the thing is only screwed into one side so it can flex out from the other side. I decided to make a small bracket that will attach to the mounting tray of the main EFIS, this bracket sticks out just enough to touch the HS34 and keep it in place. After priming the bracket I return to tying the harness.
