Still a bit jet lagged from my last trip but I did get to work lacing up the wires in the tail area. Kind of over kill but I added some clear hose sections over the areas that get zip-tied. I want to run some wires up the left side or at least have the option, so I added some conduit on that side as well. I will not be able to run much wire on this side since the step support block is in the way. I spent the last bit of time brain storming where I want to put the safety trip controller. I think I have decided to mount in on the battery try next to the ELT. I will have to make some modifications to the try to make it fit.
