Brief Description: Primed and riveted aft bulkhead parts.
After getting the shop warmed up a bit I tackled the priming of the aft bulkhead parts. I cleaned then scuffed then cleaned again all of the parts, I also did the instrument panel parts as well. Then I donned the respirator and primed all of the parts. After they set up a bit I painted the bottom side of the aft top skin to match the baggage area color and while I was at it I painted the flap motor cover to match the cockpit interior. I just had to drive some rivets so after an hour or so I dimpled all of the parts I just primed. I then riveted the seatbelt fairleads and the canopy receptacle in place. Then I riveted on the nut plates to the F808A bulkhead top and then painted it to match the baggage area. I also painted the F807 to match the cockpit. Not much but I like it when I get to rivet, it makes me feel like I am getting something done.
Parts primed
Front of F807 bulkhead
Back of F807, seatbelt fairleads and canopy receptacle riveted on
